Philips
DCC91
Second Generation Philips Mini Size DCC91.
Part of set FW91.
Donated by Marino G. Carasso.
- 360° Video
- DR DCC Video
- Technical info:
Power type and voltage: Alternating Current supply (AC) / 110-220 Volt
Loudspeaker: For headphones or amp.
Power out
From Radiomuseum.org:
Model: DCC091/00
Material: Metal case
Shape: Book-shelf unit.
Dimensions (WHD): 260 x 112 x 310 mm / 10.2 x 4.4 x 12.2 inch
Notes: Digital Compact Cassette (DCC) Recorder. P.A.S.C. signal compression algorythm, 8 parallele tracks, one running side. REC mode: only digital signal available. PLAY mode: both digital and analog signal available. In analog mode: built-in Dolby type B and C tape noise reduction.
- Net weight: 4.4 kg / 9 lb 11.1 oz (9.692 lb)91
