Philips
DCC951
Third Generation Philips DCC951.
Donated by Johan Fierkens.
- 360° Video
- DR DCC Video
- Technical info:
Type: digital compact cassette deck
Track System: 2-channel stereo
Tape Speed: 4.8 cm/s
Recording Time: 90 minutes
D/A Converter: bitstream
A/D Converter: Sigma Delta bitstream, 18 bit
Sampling Frequency: 48, 44.1, 32kHz
Frequency Response: 20Hz to 22kHz
Signal to Noise Ratio: 102dB
Dynamic Range: 95dB
Channel Separation: 85dB
Analogue Inputs: 150mV (line), 3mV (mic)
Analogue Outputs: 0.5V (line)
Digital Inputs: coaxial, optical
Digital Outputs: optical
ESI Bus
Dimensions: 435 x 90 x 300mm
Weight: 4kg
Accessories: remote control
